LabVIEW NXG 2.0
I quite got it.
I've unistalled all NXG package from the package manager.
Then searching with file manager for nxg in the whole computer resources, delted all nxg related files.
Then I've re-installed NXG without any addons or support package, so no Web module, No Vision and no DAQmx and no FPGA, SWITCH or similar.
After that, NXG was working, so I installed Vision and DAQmx and it starts crash again.
Now I'm repeating the whole procedure installing addons one by one starting from web module.
I'll let you know.
Message 21 of 25
(1,709 Views)
Deleting files manually I've deleted something too much.
Now I'd like to install web module but it says me It can't locate the package.
Can someone give me from the options of package manager, the name and location of the package for web module?
Message 22 of 25
(1,702 Views)
Hi gepponline,
Could you attach a screenshot of the message you're seeing? It may be that when installing the Web Module, your computer can't find a dependency that you've deleted on disk, and that would be useful to know.
Andy F.
Applications Engineering
Message 23 of 25
(1,673 Views)
Sorry but I can't because after a new trial, i have Web Module installed, but now the problem is that If I try to open a New webVi project it gives me this error:
Web Module:Web Server Compiler.
see screenshot attached
Message 24 of 25
(1,664 Views)
Hi gepponline,
Since I noticed you'd started a new thread for this issue, I'm going to respond on that thread.
Andy F.
Message 25 of 25
(1,632 Views)
