LabVIEW PDA gives error 12 when opening file
I can create a file with LabVIEW PDA with Pocket PC 2003, but when I try to open the file I always receive error 12 "Some system capacity necessary for operation is not enabled."
Can someone help me to solve this error ?
thanks in advance for your help.
Nico
(3,146 Views)
On the PDA, File Open returns error 12 when you are trying to open a datalog file and the datalog type you specify on the funtion does not match the datalog type on the file header.
miko
(3,066 Views)
