how can i build exe file from a vi?
Hello to all.I am a new user in labview.I want to build a execution file from vi and use it in other computer that hasn't labview.Can anybody help me?
(2,678 Views)
What LabVIEW version do you have?
If you have LabVIEW base or full, you need to buy the Application builder.
(It is included in LabVIEW professional and above. Look for deployment tools in the LabVIEW Feature Matrix).
The target machine needs the free LabVIEW runtime engine installed.
Message Edited by altenbach on 04-12-2005 09:19 AM
(2,679 Views)
Hi.My labview version is 7.0 and i have application builder and i could make the exe file But,this file doesn't work in other system that hasn't labview.what is the solution?
(2,657 Views)
As I said, the target machine needs to have the LabVIEW 7.0 Runtime engine installed. This is a free download.
(In addition, you must also make sure that your application includes any needed drivers and support files).
(2,645 Views)
