LabVIEW PDA
Hi Jabili,
I am not sure if you are asking if PDA supports serial communications, but the answer is that it does. Basically, LabVIEW talks serial using the VISA VIs or the Serial Compatibility VIs. It is left to the hardware and driver of the PDA to take those serial commands and turn them into IrCOMM. Also, have you tried using ring and enum controls with the PDA and are you getting a specific error or is this a more general question?  I’m not exactly sure which PDA would be best for your application. I would recommend looking at the PDA User Manual to see which PDAs do support the PDA module and rule those that do not off the list. I do know that PDA applications run on Pocket PC 2003 and Windows Mobile 5.0 devices.
Carla
Message 11 of 29
(6,666 Views)
hi thanks for reply  , i want more information regarding the serial communcation using Pda  and the functions  that are supprot the pda application.
Message 12 of 29
(6,087 Views)
Hi jabili,
There are a few great knowledge base articles that discuss how you can implement serial communication with your PDA device and how to use LabVIEW serial VIs to commuicate with the PDA. There is also a great NI Developer Zone article that talks about Using the LabVIEW PDA module for Serial communication. Please let us know if you have any questions regarding this information. Have a great one!
Carla
Message 13 of 29
(5,884 Views)
thanks for reply , can plese suggest me good models for pda (or) pocket pcs for  Lv pda  applications
Message 14 of 29
(5,422 Views)
hi, , i want one information  my application is run labview 8.5 pda pocket pc evaluation mode (arm processers), my qustion is is this emulator can support serial communication ?  . if support please tell me how can i implement that.
Message 15 of 29
(3,411 Views)
Hi Jabili,
The emulator can support serial communication; however, you need to setup up the emulator to do so.
Cheers,
Jonah
Jonah Paul
Marketing Manager, NI Software
Message 16 of 29
(3,402 Views)
hi jonah , i am not getting the options in Labview 8.5 , weather this otion is for labview 7.1 only are any other?
Now i am using Labview 8.5 and Labview 8.5 Pda evaluation mode  .Please  help me ... my code is Running  Pocket pc -2003 Emulator with windows
Message 17 of 29
(3,387 Views)
Hi Jabili,
For LabVIEW & PDA 8.5 you can change the serial settings by bringing up the emulator window, you can bring up the window by:
  1. Right clicking the PDA target in the Project Explorer window
  2. Click Launch Device Emulator Manager
  3. Select your device and click Action>>Connect (this should bring up your emulator)
Then once your emulator is open:
  1. Select File >> Configure...
  2. Click on the Peripherals tab and this will allow you to map your PDA serial ports to your PC's
Hope this helps! Let me know if you have any further questions related to this issue!
Cheers,
Jonah
Jonah Paul
Message 18 of 29
(3,366 Views)
hi  i open the configure window , biut i got a duobt i.e in this window i saw three options  1. serial port0, 2. serial port1, 3. serial port3. how  can i map these option , if i want to use com1 for serial communication of my device . please tell me
Message 19 of 29
(3,333 Views)
hi jonah, one more question i.e , i write code for error handling for serial port , if port connected i.e no error,if port is not connected the one button function  display device is not connected . It is works nice in pc . ,My qusetion is this works on Pocket Pc emulator ?
i am waiting ur replies
thank u
Message 20 of 29
(3,332 Views)
