LabVIEW PDA
Hi Nag123,
If I understood ur question correctly you are not clear on error handling techniques in LabView. If so go to LabView help and you would get lots of info.
What do you mean by Port is not connected and connected?
As you are already having LabView Pocket PC emulator you can try out and find on ur own. Have you tried it and asking if you are not getting?Again unable to get you? Kindly reframe ur sentences and post it again,
Please post ur code so that any one can undestand ur query better.
Pilli Ramana
Message 21 of 29
(3,696 Views)
hi Ramana,
                         i connect the Modbus init VI Error Out to case structure , in that i get two cases 1. error , 2. No Error.
If error is means , the vi check for port is connected to devices or not. if port is not connected with devices the Mod bus  Init vi gives error.
in this case i use  the one button Disaplay devices is not connected . This works fine on the computer  application. IThe same opertion not display in the emulator. Can u please tell me reason why it is not showing. I used the Pda function palette.
Message 22 of 29
(3,685 Views)
i tried on pocket pc emulator but i am not get the operation , which i am explain above post
Message 23 of 29
(3,683 Views)
hi jonah , please tell me  answer for  configure of emulator
Message 24 of 29
(3,680 Views)
Hi Jabili,
First of all to clarify are you using the Modbus Init VI from the nimodbus.llb library (can be found here)? If so I was able to drag the Modbus Init VI to a PDA VI that I ran on a Pocket PC 2003 SE Emulator (see attached VI). It did correctly display that the Modbus is not connected; however, I have no method to verify when it is corrected.
Please run the attached VI on your emulator and let me know if it is successful.
Cheers,
Jonah
Jonah Paul
Marketing Manager, NI Software
Message 25 of 29
(3,661 Views)
hi jonh, thank u for help..
Can u plz give suggestion which   model POcket  pC  Can support Mod- Busserial communcation with  mpcro controller device , I want model name , Product detalis , suitable connector details .please help me.Now i have done serial communication using POcet Pc emulator 2003.
Message 26 of 29
(3,643 Views)
Hi Jabili,
Unfortunately, National Instruments cannot recommend specific PDAs for your unique application. Please let me know if you have any further questions regarding the NI LabVIEW PDA module or other software application concerns.
Cheers,
Jonah
Jonah Paul
Message 27 of 29
(3,634 Views)
hi, Can  plz  Tell me at least one pda example model. which will support the serial communication  with  oter device using with Labview PDA Application.
hi, Can u plz tell in the below connector RS-232 (DB9) , can i use for serial communication  PDA ----> to-----> My Micro controller device. is it also work for sync purpose of  Pc -----> to Pda to deploy the application using  com port of pc. please tell me with ur experiance
Message 28 of 29
(3,617 Views)
Hi Jabili,
I unfortunately do not have any experience with this cable; however, when I followed the link that you posted it did appear that the company selling this product has a contact link "Questions? Contact Us". I would recommend, since they would have the most experience with this specific cable, contacting them and asking the same question. Please follow up and let me know the outcome of this inquiry.
Cheers,
Jonah
Jonah Paul
Message 29 of 29
(3,586 Views)
