LabVIEW PID controlled PWM output
Dear All,
I need to control the heater with set temperature. My idea is to use PID control which can output duty cycle percentage and in-turn generate the PWM signal to control the SSR using single board RIO with 1 KHz frequency.
I have searched the forum for previous post. But unfortunate to find right one, most of them uses DAQ to generate variable duty cycle PWM output. Hence am using RIO digital I/O line in RT, am not familiar on how to proceed.
I would be happy to see the replies.
Message 1 of 18
(14,130 Views)
you can use attached vi and link the output to Digital Output port of RT. The vi has two inputs: "PID output (%)" which you connect to your PID controller and "PWM period (sec)" which specifies the lenght of PWM period. For heater I ussualy set something between 3 to 10sec. For better resolution I usually use heater  with more heating elements and split PWM into more parts.
BR, Jan
Message 2 of 18
(14,098 Views)
BR, Jan
Thanks for reply. Attached vi is protected, if don't mind can you share the password.
Message 3 of 18
(14,093 Views)
Accepted by lv_user_bs
Sorry, my fault 🙂
Here you are
BR,Jan
Message 4 of 18
(14,064 Views)
Hi JanBarton,
Thanks for your time. Can you please help me out to understand the logic because am new to this.
Message 5 of 18
(14,055 Views)
it is easy. A simple sawtooth  signal is built representing a value from 0-100 of period time. This signal is compared to wanted output value. If the value is  higher than the current value of sawtooth signal the output is high. See fig.2 on this webpage  https://en.wikipedia.org/wiki/Pulse-width_modulation
BR,
Jan
Message 6 of 18
(13,964 Views)
hello sir
Can you make a screenshot of the code ?
because i have labview 2015.
thank you
Message 7 of 18
(12,633 Views)
Hi nad,
I took the liberty to simplify the VI a little bit:
Message 8 of 18
(12,625 Views)
Thank you !
Another question : In tick counter, why do use ms like counter units ?
I think it's good  if you use ticks  unit.
and why do you multiply the result of substraction by 0.001 ?
Message 9 of 18
(12,602 Views)
Hi nad,
The OP decided to use that VI (most probably) on a RT target, with using a millisecond tick counter…
Depends on the target you want to run that code on…
Because the control is named "PWM period (sec)" and your tick counter gives ms: there's a conversion factor of 1000 between both units…
Message 10 of 18
(12,597 Views)
