LabVIEW Programming
Hi Teddy,
You can read from a Local Variable of the Graph prior to plotting anything to it.
If you have previous plot in the graph, it will return what you plotted down previously.
If you don't have anything, it will return an uninitialized array.
Then, you can feed this array to a For Loop with Auto-indexing.
If the array is initialized, the For Loop will execute twice (since the array has two elements) and return a Boolean array [True, True].
If the array is uninitialized, the For Loop will not execute (since the size of the array is 0), and it will output False (the default value of Boolean data type).
After that, by converting the Boolean array to number, you will get 0 if there is not previous plot in the graph, and non-0 if there is any plot.
And you can wire this value to a Case structure for any codes that follow.
Hope this helps.
Guo Min
National Instruments ASEAN
Message 11 of 35
(2,558 Views)
Hi Teddy,
In LabVIEW, there is no way to change the color of the cursor name independantly of the cursor's color, since they are bundled as one.
If you really need to do this, the only way I would suggest is to create two separate cursors, one not showing the cursor name and one with the cursor name.
Then you will be able to change the color separately, and you can use the property node to synchronize the position of the two cursors.
Guo Min
Message 12 of 35
(2,530 Views)
Hello
Thank you for all the help. I have another question. Suppose there are two arrays A and B.
A has values 1,2,3,4
B has values 2,4,6,8
And these two are plotted in an XY graph with A as x axis and B as y axis.
Is there a way to obtain the Y axis value when X axis value is 1.5? Technically the Y value should be 3. Is there a way to get this from the graph or from interpolating the arrays?
Message 13 of 35
(2,514 Views)
Hi Teddy,
There are a few interpolation function on the functions pallet under signal processing » pt by pt » Interpolation. You could also use a function node and calculate the interpolated point yourself based on the signals characteristics.
But to answer your question, the graph cannot perform any of these functions. You will need an external function to calculate the interpolated point.
Sappster
Message 14 of 35
(2,502 Views)
Thank you for your reply. I also want to know about the Report generation Toolkit. I have it installed, but I am unable to see the VIs in the block diagram. Once the report gen toolkit is installed, where should I copy the llb file to be able to use the report gen toolkit?
Thank you in advance
Message 15 of 35
(2,423 Views)
Hi Teddy,
Are you trying to install the toolkit to your LabVIEW 8.5? Do you have multiple versions of LabVIEW installed in your computer?
What version of Report Generation Toolkit did you install? Where did you get the installer file and how did you install it?
Normally after a successful installation of the toolkit, you don't need to copy any .llb files.
You will be immediately able to find the VIs in the Fucntions Palette>> Programming>>Report Generation
I suspect your problem may be a result of either installing the wrong version of toolkit or installing the toolkit to multiple versions of LabVIEW.
Guo Min
Message 16 of 35
(2,398 Views)
Hello
Thank you for your reply. I will reinstall the toolkit and try again. I also want to know another thing. If I use the toolkit to generate a MS word document, can I open the created document and display the data in a strng indicator? Kindly attach a sample if possible.
Thank you
Message 17 of 35
(2,375 Views)
I would kindly like to know the following
1. How to display a picture on the front panel
2. Are there any more sound VIs similar to beep.vi? If so, from where can I get them?
Thank you
Message 18 of 35
(2,332 Views)
Hi Teddy,
I couldn't find an easy way to extract the contents in a Word document, since the file contains a lot of formatting information.
You can try to open the file as ASCII (same as what you do to .txt files), and you will see the contents together with many "trash" information.
If the .doc file only contains tables, I would suggest you save these tables using Excel. In Report Generation Toolkit, you can find some functions under Excel Specific to do so. I've attached a simple example for this.
Nontheless, you can access the information in a .doc file by making ActiveX calls in LabVIEW to control MS Word, but it's more complicated and troublesome, and I wouldn't recommend it to you.
Guo Min
Message 19 of 35
(2,302 Views)
Hi Teddy,
Regarding your last post, please see below for answers.
1. To play other sounds, you can wire a False constant to the "use system alert?" terminal of the "beep.vi", and modify the frequency and duration of the sound you play. You can play more sounds using the Play Waveform Express VI located in Functions Palette>>Programming>>Graphics & Sound>>Sound>>Output, but you need an output device (speakers, etc.) to use it.
2. To display a picture, you can use "Draw Flattened Pixmap.vi" in Functions Palette>>Programming>>Graphics & Sound>>Picture Functions
If you want to display the picture from an image file like .bmp or .jpg, you can utilize "Read BMP File.vi" or "Read JPEG File.vi" in Functions Palette>>Programming>>Graphics & Sound>>Graphics Formats.
I've attached a simple example for displaying a .jpg image.
You can find more example codes using the Example Finder.
Guo Min
Message 20 of 35
(2,293 Views)
