LabVIEW RT does not supports only 8 CPU cores by default. Need More.
I have installed LabVIEW Real Time 2011 on a desktop with 24 CPU cores.
However LabVIEW Real Time support a maximum of 8 CPU cores by default.
Need help configuring LabVIEW RT to utilize all 24 CPU cores.
Kevin
(3,888 Views)
Does this thread sound familiar?
Ben
(3,883 Views)
Ben,
I have used threadconfig before, on a WinXP system with four cores.
I thought that I needed more threads, but it turned out I needed more memory.
Seams that when I added a second diaplay card my memory went from 3.2GB down to 2.0GB.
This is a bummer on a 32 bit OK.
However now my problem is with LabVIEW Real Time only supporting 8 CPU cores by default.
My Real TIme system has 24 CPU cores.
Is there a threadconfig for LabVIEW RT?
Kevin.
Some have already decided on coal.
But what is the alternative?   .....
Time will have to tell for fracking.
I still believe that being able to
place a Tab within a Clustor would
solve all the worlds problems.
(3,853 Views)
DId you try running on the RT machine?
Roy mentioned in the thread I linked that threadconfig writes an entry to the ini.
Chase down the switch he mentions and try putting that in the ini file on the RT to see if that does what we need.
Just trying to help,
Ben
(3,844 Views)
Ben,
threadconfig lets you designate the maximum number of threads per execution engine.
The defaults are dependant on the number of CPU Cores available.
However, LabVIEW RealTIme recognizes my 24 cores at boot, but then disables all but 8 of them.
So in the mindset of "threadconfig.vi", I made my own "CpuCoreConfig.vi".
Thank goodness I only have 24 cores, because the concel window on LabVIEW RT has only 25 lines.   Smiley Happy
To the best of my knowledge, NI has not fully tested LabVIEW RT with more than 8 CPU Cores.
Kevin
(3,798 Views)
@kmcdevitt wrote:
Ben,
Kevin
Cool!
So when I get hit with the same question coming from my bull-pen, ... Is there anything that you would like to share that would make repeating your feat easier?
Curious,
Ben
(3,767 Views)
