gradient of triangle point by point
I have a problem with evaluating the gradient of a triangle signal.
To check the connection and the module of a 9144er chassis we are generating a triangle signal on the master and set it on an AO module. This signal is bowed to an analog in module. On the controller I compare the signal of the AO-module with the AI signal.
My problem is, that when there is e.g. a broken wire on the AI module of the slave the last written output is still set.
Has anybody a suggestion to evaluate this analog watchdog? Maybe with a gradient function? I've tested it with a linear equation and inverted the k-part on the top, but the result isn't as expected.
Thanks for your hints.
Best Regards,
Joachim
(2,441 Views)
Dear Joachim,
what do you want to set at the output?
what do you aspect?
If you want, you can post in german 😄
rgds
(2,410 Views)
