LabVIEW RT intel chipset compatibility
Is it possible to get an updated list of Intel network chipsets compatibles with LabVIEW RT 8.20 ?
What about Intel 82551ER and 82562ER ?
Jean-Louis Schricke
Jean-Louis SCHRICKE
├ CTA - Certified TestStand Architect (2008 - 2022)
├ CTD - Certified TestStand Developer (2004 & 2007)
└ CLD - Certified LabVIEW Developer (2003 & 2005)
(4,036 Views)
You can found on this link : http://digital.ni.com/public.nsf/websearch/CB3434DA94466DD286256E9E006BB775?OpenDocument, supported Ethernet chipset on LabVIEW 8.0.
I am searching if we have add other chipset support on LV 8.2, i let you know if i found something.
Christophe S.
Account Manager East of France І Certified LabVIEW Associate Developer І National Instruments France
(4,003 Views)
You can found on MAX a utility shipping with LV 8.2 for test compatibility, you can run it in your system to make sure that your system is ready to be converted to RT or not. You have the option to add a supported network chipset by getting the real time deployment license budle.
Christophe S.
(3,973 Views)
Thanks Christophe,
I already downloaded this utility. It is fine.
But it doesn't answer completely my question.
I suppose that National Instruments has this compatibility list.
I need to know wether a PC is LabVIEW RT compatible before getting it, and not after...
Jean-Louis SCHRICKE
(3,940 Views)
