compiling error, "linker.cpp, line 2075", LabVIEW 6.0.2
Why do I receive a  "linker.cpp, line 2075" error when building an application with LabVIEW 6.0.2
(3,095 Views)
Hi CEY,
I hope you're doing well.  There could be a variety of things that can cause an error such as the one you've mentioned.  Does this happen on every executable that you trying to compile, or just a particular one?  We'd like to see if we can isolate the error to a specific piece of code, or compiler options.  Searching through past Discussion Forum threads, I was able to find a similar error message in the following thread.  It looks like they were able to mass compile and solve their issue, so this may be tied to your issue as well.  If you need help mass compiling your VI, take a look at the following KnowledgeBase.  Let me know if this helps, and if not, the more details you can provide about what conditions the error get thrown in will be helpful.  Have a great day!
Thaison V
(3,076 Views)
Yeah I would agree with the other post. Try a mass compile (the link mentions LabVIEW 7.X but it is true for 6.X as well, so don't be put off). It can take a while and a full system backup isn't a bad idea either, first. Defrag your hard disc as the perfomance will be better if the hard disc is tidy and watch out for crosslinked files, hence the backup suggestion (Windows in particular).
If you have installed a later version of Labview (and accidently compiled a common routine) or moved in some VI's from another version, it can get confused. Possibly you have accidently moved in or a VI is being included via a path statement, that is causing the problem.
Of course you will have some backups of the versions that worked 😉 - So you could go back. But I found in the past it was generally in a Library routine / shared library(s), not always included in the backups held for the project (library routines being backed up with a full system backup and also availalble from source distributions). On the odd ocasion I had to sort out which library(s) needed refreshing, even from the original distribution. But hopefully the mass compile should clear it all up.
(3,059 Views)
