LabVIEW RT usage
Can LabVIEW RT application run on Windows CE 3.0? I have an control device which support Windows CE , I hope I can use LV to construct the HMI and control the target .
David
(3,997 Views)
Hello David,
You can not use LabVIEW RT to run on Windows CE, however LabVIEW PDA for PocketPC will run in Windows CE if certain requirements are met. Check the following document for all the details.
Using LabVIEW to Develop Applications for Windows CE Devices [link removed; article no longer available]
Christian L
NI Consulting Services
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
(3,997 Views)
