VI Slow Down/performance
Hello All!!,
I have a question about performance. I created a VI that creates some dummy waveforms, does some processing to them, and displays the results. Pretty basic. I decided to simplify the Vi by putting all of the processing algorithms into a sub vi. When I did this the VI slowed down significantly. Like about five to ten times. The code in the sub VI is exactly the same as when it was just lying in the top level vi. I even saved two versions and compared them. The processing is some FFTs and a little complex math, but I don't see how that is important. Does anybody have an explaination as to why I am experiencing such a drastic slow down? and maybe how to deal with it without keeping my code on the top level. Any help would be gla
dly appreciated. Thanks in advance.
Glen D.
Message 1 of 10
(3,725 Views)
Normally introducing a sub-VI is trouble-free and as you say it's better to arrange the code that way. If the code is to be called repeatedly (thousands of times) and it all needs to finish as fast as possible the accumulated overhead introduced can get significant and you must skip the sub-VI.
(I actually suggested to NI two days ago to add a feature in LV where you can organize the code in a sub-VI and set it to "flatten when compiled" (or a new type of object) only for organization purposes and then have the compiler flatten the code to optimize performance).
When it comes to memory usage the story is a bit more complicated. If you do not have the front panel in memory that will prevent some copies from being made, however even with the front panel removed
/ not in memory the sub-VI may introduce data copies. If the data amount is large (which is perhaps the case here?) this can be costly.
Normally that would not give much of a performance penalty though - but if the amount of memory available is too small and the software must use virtual memory (disk) you can quickly get a significant performance drop.
Could lack of memory be an issue here? If not, could you post the caller and sub-VI?
Message 2 of 10
(3,725 Views)
Hi Glen,
Could it be that you're updating indicators on the main VI panel through references in the sub-vi? I know LV does this automatically sometimes when you make a sub-vi out of an existing piece of code and as far as I know uses a lot of CPU time...
Even still, 10 times slower is really a lot.
Hope this helps
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
Message 3 of 10
(3,725 Views)
Thank you for your response. However, I do not think that lack of memory is an issue. I am running 512MB on a P3 with Win98.
Here are the VIs. There maybe some minor display differences between the two, but I just made those since the first post and they should not effect anything.
Message 4 of 10
(3,725 Views)
Nope, I am not passing in any references. I just posted up the VIs if you would like to take a look.
Message 5 of 10
(3,725 Views)
Sorry, to see the differences in performance, set the "speed" switch to the left position. Then compare how quickly the X-axis increments. The one without the sub vi goes more than 10,000 points in a second. While the one with the sub vi does more like 1,000.
Message 6 of 10
(3,725 Views)
I could not notice any speed difference. If the one without sub-VI is set to full speed then yes the one with sub-VI will slow down because the other one is taking all the CPU time, however that works the other way around too (if you set the sub-VI type to full speed first).
Message 7 of 10
(3,725 Views)
No, I did not compare when both were running at the same time. I only ran one at a time.
So perhaps it is my system then. I will carry on. Thank you for your help.
Message 8 of 10
(3,725 Views)
code on the top level. Any help would be gladly appreciated. Thanks in
> advance.
I looked into it and I can sort of explain it, to myself. I'll bounce
this off some others at work tomorrow so that I can explain it better.
In a nutshell, the time isn't being spent executing the subVI. By using
the profiler, and letting both VIs run about five seconds, the single
subVI solution accounts for about five seconds, and much of the time is
spent in the top level diagram. In fact, the case statement is only
executed about 100 times.
When I run the subVI edition for about five seconds, there is some
missing time. The time spent in the VI is something like 1.5 seconds
including the time spent in the subVI. Indeed, the VI did run slower,
because it spent most of its time waiting for LV to schedule it. At
least that is my theory. I played around a bit and figured out
something that makes the subVI version runs the same speed.
I'll check back tomorrow.
Greg McKaskle
Message 9 of 10
(3,725 Views)
OK, I feel like I finally understand what is going on here, and it is a bit of a wierd one. It has very little to do with the subVI except that the subVI reorganizes the code and provokes this.
The outer loop is running quite fast and the case structure's contents run very rarely and have little impact on the execution speed. The problem is that the contents of the case statement contain the property node to read the history of the chart. In the fast code, the loop runs in the Std Execution system and occasionally, inside the case statement, it needs to transition the execution to the UI thread to get the history value. It may stay in the UI thread awhile, or it may immediately switch back. Either way, there are just a few of these transitions. Each of them adds overhead, but compared to the work being done, the overhead is pretty small and acceptable.
In the code that runs about 8x slower, the UI-ness of reading the history is leaking out to the case statement itself. The outer loop starts running in Std, then to execute the case structure, including the empty diagram, it transitions to the UI execution system. After the loop it could stay in the UI for awhile, but you also have the asynchronous Wait MS Multiple and that tends to push execution back to the original thread. With both of these in the same loop, we have 750 times more execution system swaps than in the original code. If the code in the loop did more, it would probably shrink back into the noise, but at the moment the loop runs fast enough that this extra cost means an 8x loop rate penalty.
Morals?
This is one of those unfortunate times when the static analysis LV does on the diagram fails us and LV guesses wrong. It assumes that since some of the code needs the UI thread, you are better off moving most of it and amortizing the cost. Unfortunately, something else isn't playing along and we end up being penalized. The good news is that this alignment of the stars doesn't happen very often, and it shouldn't be something you really have to worry about. And this is something we are constantly tweaking to get the best performance in the typical usage.
The thing that provokes this is mixing UI and data computation in the same loop. In particular, the chart's history buffer is being used as the circular buffer for the analysis. If the circular buffer was shift-reg style, the whole diagram would be running in the same execution system and it would be still faster than even the fast loop here.
So I guess the thing to take away is that using the chart as a quick and dirty circular buffer is sometimes too quick and too dirty and can gum up the works.
Greg McKaskle
Message 10 of 10
(3,725 Views)
