LabVIEW Run Time engine not found on an application created in LabVIEW
I created an .exe application from a LabVIEW project that works fine on the computer which has LabVIEW. But when I tried to run it in a different computer its showing error LabVIEW run time engine not found. I googled it and found that it is because an lvrt.dll file is missing. How can I create the .exe application with the lvrt.dll file so that I can run the application in any PC?
(3,387 Views)
Accepted by govindsankar
Hi Govindsankar,
as with any other executable is done also: create an installer!
(To create an installer is another option in the AppBuilder…)
(3,368 Views)
You can't. At least not easily.
You can
1) Create an installer that installer the RTE and the executable
2) Install the RTE manually (download and install), and the executable will run.
The RTE is required, and needs to be installed. It's (very) hard to get around that.
(3,361 Views)
