LabVIEW Runtime engine on Windows Embedded Standard 7 P 32/64 bit?
Did anyone ever try to install and run LabVIEW Runtime engine (2011 or later) on Windows Embedded Standard 7 P 32/64 bit?
I am trying to figure out if this will work, for example on a Beckhoff CX5120 embedded PC. I will need to have some simple TCP/IP communication in order to exchange information with another PC, but nothing else, i.e. drivers, etc...
I hope someone tried to do this already. I just don't have the right hardware right now to check it out.
(3,889 Views)
Accepted by topic author chembo
As NI sells touch panels with WES7 installed here: https://www.ni.com/en-us/support/model.tpc-2215.html it's pretty safe to assume they've used the RTE on WES7.
But yes, it's been done.
(3,872 Views)
