how we can using timer in LV2013 and how we can use chart ?
Hi.
1. I use a case structure in my program and I want it exceute when a triger comes only for 200 ms (or other integer ms) and then it wait for new triger.
how I can implement this in LV2013 ?
2. we can use chart for display data for 200 ms (or other integer value), how we can display data in 200 ms segments. i.e. data from 1s divided into 5 part with duration of 200ms and all of them (5 part) shows in the same chart ?
(2,780 Views)
You didn't mention what your level of experience is with LabVIEW. What you want to do is not trivial, but not particularly hard either. Basically you use an event-driven structure and put your you want perform in the timeout event. All you have to do is toun the timeout on and off to start and stop your processing. I'll post a link in a little bit -- traveling right now.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,769 Views)
my data comes from serial port. and I want check them if input data had been greater than my specified value then display them in chart for 200 ms (or other specified time). after this time data will not be displayed in chart until input data be greater than my specified value. so this procedure repeat again and again.
(2,756 Views)
Serial IO is going to make 200-msec difficult since serial is inherently very sloppy in terms of timing. It would be better if you could characterize the acquisition in terms of the number fo samples to be read. That you can do very easily.
Ok, here is the link that I promised. This example doesn't show exactly what it is that you are trying to do, but it does demonstrate a technique for starting and stopping a process programatically.
Mike...
LabVIEW Champion
(2,745 Views)
