LabVIEW Sound and Vibration Toolkit, and Electrical Power Toolkit
when will  LabVIEW Sound and Vibration Toolkit 2024 and Electrical Power Toolkit 2024 be released ?
(674 Views)
Hi there
The short answer is probably never !
The longer answer is that both toolkits support the new Addon concept. This means that you don't need to upgrade the toolkit versions to match the LabVIEW release version. As this release information says :
Application Software Support
The following table lists the NI application software versions, including service packs, supported by LabVIEW Sound and Vibration Toolkit.
NI Application Software Versions Supported by Labview Sound and Vibration Toolkit 2023 Q3
NI LabVIEW Full or Professional Development System 2022 Q3 and later
NI LabVIEW Real-Time Module 2022 Q3 and later
Regards
(648 Views)
