Passing updated private cluster data within the actor core of an actor
I have an actor and the actor has some private data. I create a method vi to update some of its private cluster data. Then I create a message out of it. Then in actor core, by using the read self enqueuer I send the message I created earlier to the actor itself to  update its private data. But now if I unbundle the actor again after sending the message to see if the private data has been updated, I see it has not been. So that is now how actors work. I cannot pass the actor data within the actor core by sending messages. I have to directly send the data within the actor core. Is that how it works?
(898 Views)
Accepted by topic author govindsankar
Reading your question in the context of new AF developers, I think what you are doing is forking the actor wire and expecting one fork to update data on the other (apologies if I'm misreading!). The wire is a normal, by-value LabVIEW wire not a channel wire or anything fancy, so one fork doesn't affect the other unless you add another communication mechanism like a DVR inside that is by reference and not by value:
(871 Views)
Of course, reference, yes thats how you do it. I forgot, i havent done actor frame work and i dont have that much experience in it. I remember updating the values in the past, but i forgot how. Yes by using references. Thank you. I feel like an idiot. And yes I was forking the wire. Thank you
(851 Views)
