LabVIEW Student Version
Hello - I'm new to LabView. Purchased LabVIEW Student version about 1 year ago. Just starting with it now.
First problem I've encountered is wiring the 'Read" block to a gauge. I have a type mismatch.
Is there a way to re-configure the 'read block' to 1 channel, single sample? I'm following along an older YouTube video and the palette choices I have don't match the video.
Is this because I have a limited Student Version? Also, is DAQ Assistant gone? I can't find that either - it appears in the video.
Thank you all.
Gary P.
(4,291 Views)
GaryatNeo wrote:First problem I've encountered is wiring the 'Read" block to a gauge. I have a type mismatch.
Which "Read" are you referring to?  I'm guessing DAQmx Read.  A snapshot of your code would help use a lot here.
No, the DAQ Assistant is still there.  You might need to reinstall DAQmx in order to add the LabVIEW support.
(4,274 Views)
Thank you for the reply. Yes, it is a DAQmx Base READ function. When I try to wire it to a gauge, I get the typemismatch.
I also see now that there is also a second error - Task/Channel not wired.
I do not know how to provide a snapshot of my code yet.
Also, Should I be on another board - I don't want to take up anyone's time with beginner questions if I should be somewhere else.
(4,262 Views)
Why are you using DAQmx Base instead of regular DAQmx?  What OS are you using?
(4,255 Views)
I'm using Windows 7
(4,251 Views)
Accepted by topic author GaryatNeo
DAQmx Base is meant for Macs.  And I think it doesn't include the DAQ Assistant.  See the OS listed here https://www.ni.com/en/support/downloads/drivers/download.ni-daqmx-base.html#326059
You should remove it and install regular DAQmx.
(4,247 Views)
