LabVIEW TCP/IP Read via Ethernet from Wiznet 5500 EVB Pico
Hi folks,
Objective: Read Distance measurement data from Wiznet 5500 EVB Pico via TCP/IP
Pico IP - 10.10.10.112
Port: 23
Protocol: TCP/IP (Client)
Application Details: I am reading digital measurement data off a Mitutoyo digital scale by using a Wiznet Pico. I have a sketch that runs on the Pico to get the distance data and send it to the network. I am hoping to have the distance data on LabVIEW using TCP/IP. I've made sure that the protocol is TCP/IP and I used the YAT terminal software to read the data off the Pico on the computer. So then i tried to use LabVIEW to do the same and i haven't had any luck to read the data. With the YAT terminal software i am not sending any commands to start getting data streams, instead i am opening the port connection and reading the data off it. I am attaching the YAT terminal pictures (sorry about the picture quality), the Pico Sketch and the Vi's I've tried so far.
I have tried the LabVIEW example vi and other VI from discussions and haven't had any luck. I'm hoping I can get a solution from the discussion here. All help, suggestions, remarks are all appreciated.
The "TCP Monitor" vi is more of what i was trying and experimenting to see some results, and the "TCP Monitor Type 2" is the LabVIEW TCP client example vi.
Message 1 of 1
(689 Views)
