Weird output reading datat from tab delimited text file
the task: to read data from a tab-delimited text file
the problem: it shows strange output (it should show double numbers but instead it shows only integers)
solutions that I have tried :
1- I tried two methods to read the data (read from a text file and read delimited spreadsheet), and I got the same results.
2- I tried to change the format [%.3f] (in case of read delimited spreadsheet) to different things but it was worse.
I think the problem is in my laptop configuration or the LabVIEW configuration! because I tried the same data on my friend's laptop and it worked well (it shows a usual ECG signal).
(1,696 Views)
Accepted by topic author Adham_m
Hi Adham,
your text file contains the numbers using a comma as decimal separator, so you may try the "%,;%f" format code…
(1,684 Views)
yeap , it worked 🙂 , thanks for your fast reply and precious help
but can you explain how can i avoid this in future , from where can find this format  (%,;%f) , cuz i looked up in the help for [Read Delimited spreadsheet ] and found nothing helpful (just%d for integers and %s for strings)
and another question : why the same text file worked normally on my friend's laptop without changing the format !?
thanks in advance
(1,667 Views)
Hi Chad,
When you read the paragraph on the format string input then you will notice a link to "format string syntax". Follow the link and read…
Because those functions respect your local regional settings. Your friend seems to use German settings (comma in numbers), while you use English dot decimal separator…
(1,658 Views)
Totally right !
Thanks Again 🙂
(1,647 Views)
