LabVIEW Touch panel module & Windows CE 6.0 based HMI
Dear All
we are choosing an HMI for our sbRIO based system at our customer
now we have a specific HMI that I wish to make sure will work fine with LabVIEW Touch Panel Module (2010 or 2011)
attached you can find a pdf file containing the datasheet for the HMIs of interest (Page3)
they are from BrainChild,  based on WinCE 6.0 Operating system , ARM 11 or ARM Cortex A8 processors
Thanks in advance for your cooperation and valuable time
Eng. Mohammed Ashraf
Certified LabVIEW Associated Developer
InnoVision Systems Founder, RF Test Development Engineer
www.ivsystems-eg.com
(3,724 Views)
Hi Mohammed,
Windows CE 6.0 is not officially supported by the Touch Panel Module (see this link for more info and what is supported). Other members on our forums (link) have tried working with CE 6.0 but since it isn't officially supported and you're still in the planning stage of your application, it might be better to choose a HMI that is directly supported.
Tim W.
Applications Engineering
http://www.ni.com/support
(3,697 Views)
