Tdms-Writing 1D string to multiple channels
What is the best way to write (lets say) 20 data points to 20 different channels simultaneously? i.e. one data point to each of 20 different channels. The data type is 1D array of string.
The 'channel name(s)' terminal on the Tdms Write .vi will not accept a 1D array of string because of my data type. My data type can not be converted because it is alphanumeric.
My idea was to do something like this minus the custom properties
http://zone.ni.com/devzone/jsp/largeImage.jsp?imagename=/cms/images/devzone/tut/TDMS_API_VI_Snippet....
Except with the data Being a 1D string array instead of Double.
Ryan
(6,513 Views)
Maybe I could leave the 'channel name(s)' terminal unwired and allow LV to automatically name 20 channels, and then use the 'set channel information' function to name them after the data is written?
(6,512 Views)
Accepted by topic author Ryan Cattley
wire the 1d array of string data to a "build array" primitive to make it a 2d string array with only one row.  wire this to a "transpose array" to make it one column. (I believe it expects channels in rows, I could be wrong, test it.)
-Barrett
CLD
(6,479 Views)
This worked. I probably never would have thought to do that, thanks.
(6,475 Views)
