LabVIEW Version
I think this would be roughly equivalent code for this part (input data extracted from graph defaults):
(no guarantees, because I cannot run the original because of missing subVIs).
And as has been already said, the linear fit and linear evaluation would be trivial to implement from "Base" primitives.
Message 11 of 12
(1,382 Views)
One possibility:
Note that you might want to implement some sanity checks on the inputs, such as verifying that [X] and [Y] have equal size. (other checks are less important, such as the presence of  at least two points and absence of NaN, +inf, -inf, etc. Violating any of these will just return NaN, which might be sufficient.)
Message 12 of 12
(1,334 Views)
