LabVIEW WebDAV VI isn't functioning on some laptops
I'm using WebDAV VIs to transfer files to a cRIO 9074 per this link. The LabVIEW executable works on some laptops but not on others (all machines have the same version of the LabVIEW Run time engine installed). On the laptops where it does NOT work, I can still transfer files using 'Map Network Drive,' indicating a connection exists. However, I'm unsure why the LabVIEW WebDAV exe isn't functioning on those machines. Does anyone know what Windows settings might need adjustment for those experiencing issues? Could it be related to firewall blocking (again map network drive works fine which I think uses port 80 based on Wireshark capture)?
AH
(854 Views)
Map network drive definitely does not use port 80 and your link is confusing because the image shows "https" while the text says "http".
(837 Views)
