10-25-2024 08:18 AM - edited 10-25-2024 08:19 AM
Hi, community!
I am trying to use VISA Write command to send a very simple test script processor (TSP) to my Keythley 2602b. This is my code:
x = 0
y = 2
if x and y then
print("Both x and y are true")
end
Simple, right? However, error occurs in this step, which states:
Keithley 2600 Series.lvlib:Error Query.vi<ERR>
Instrument reports:
-2.85000e+02 TSP Syntax error at line 2: `end' expected (to close `if' at line 1) near `<eof>' 2.00000e+01 1.00000e+00
-2.85000e+02 TSP Syntax error at line 1: <eof> expected near `end' 2.00000e+01 1.00000e+00
0.00000e+00 Queue Is Empty 0.00000e+00 1.00000e+00
I am so comfused. It seems that there are syntax error of the lua language, but I fail to debug it. Please tell me the problem here!
Please find my LabVIEW code in attachment.
10-25-2024 12:22 PM
I cannot comment on the LUA part and I a missing your drivers.
I assume that your instrument communication is correct and that it is safe to leave the communication settings unwired. Does the response include a termination character?
Some quick comments on your code:
Since this is mostly about controlling an instrument, there might be a better place for this discussion. I can move it if you want. Let me know.
10-26-2024 02:31 AM
Thanks for your reply! I have solved my problem so I want to update my solution.
I appreciate for your comments. They are only for debugging, and not what caused my problem.
The problem is that: 'VISA write' seems to convert all my command to one line string. What's worse is that it even convert the line break ('\n') to '.'! This is truly fatal. I confirm my assumption via inspection on NI I/O Trace:
Therefore, the solution is straightforward and not elegant: rearrange all the command in one line as 'if x and y then print("Both x and y are true") end'. Solved! ...
Even though I locate the problem, there's literally nothing I could change regarding the mechamism of 'VISA Write'. Is there better way to communicate with my instruments? Can I send them script in multiple lines?
