LabVIEW Webservices - Not able to perform HTTP DELETE request
Hi All,
I'm not able to perform an HTTP DELETE request from the client. I can perform Get and POST requests without any error. In the below project I would like to have the Deinitialization method as DELETE verb but when I convert the method to DELETE it's not working, the same method is working when it is GET.
Working:
Command:
curl -X POST "http://localhost:8001/WEBSERVICE_NAME/Deinitialize" -H "accept: */*" -d ""
Not Working:
Command:
curl -X DELETE "http://localhost:8001/WEBSERVICE_NAME/Deinitialize" -H "accept: */*"
Can some help with this?
Thank you
Message 1 of 1
(2,167 Views)
