LabVIEW & TDS 3024B Oscilloscope
I am new to LabVIEW, can some one help me how to interface a TDS 3024B Oscilloscope with LabVIEW.  If I need any components or cables, anything like that please let me know. Thanks
(3,221 Views)
There is a driver for that instrument here and according to that page, the supported interfaces are GPIB, Ethernet, or serial. A GPIB connection will require a controller in the pc. With the Ethernet connection, you could connect the scope to your LAN with a standard network cable. You could also connect it directly to your pc. If you do a direct connect, you would need a crossover network cable. For a serial connection, you would probably need a null-modem serial cable and a serial port on the pc. A serial connection is going to be slow for waveform transfers. A GPIB connection is going to be pretty fast with low latency but requires a controller (~U$500) and special cable. The Ethernet connection is going to be fast but with a higher latency. If my memory is correct, an Ethernet connection is a bit more limited in the trigger options. I'm not sure if you can do a bus trigger like you can with GPIB. If you go with the Ethernet connection, you might want to consider using a dedicated NIC card in the pc and on a different subnet than your network.
(3,210 Views)
Thanks for the information Dennis, could you give me more advice about the GPIB connection (any specific cable, controllers..)
(3,204 Views)
here is the main page for NI controller and cables. I would strongly recomend a controller form NI. For cables, you have a lot of other choices. We've been buying most of ours from L-Com lately. They have a wider variety to choose from.
(3,195 Views)
