LabVIEW and Honeywell Read-out Box
Okay I have made it work!!! It can run and can show the current pressure values. Thank you so much, this could have not happened without you!!!
Still, I want to ask how to fix the error in the screenshot attached. We intend to have the data value at each second to be recorded and stored them into array on Notepad so that we can later manipulate them in Excel. Any suggestions?
Message 21 of 22
(493 Views)
Hi seb,
@seb_Dai wrote:
Still, I want to ask how to fix the error in the screenshot attached. Any suggestions?
Use the correct filepath so you don't get this "wrong filepath" error…
Record your data in a CSV file (aka "delimited text file" aka "spreadsheet file"). No need for "array on Notepad" (whatever this may be as Notepad only handles plain text) when you want to import the data in Excel…
Message 22 of 22
(484 Views)
