LabVIEW and Vista
We're about to move to VIsta using LabVIEW and I'm sure a lot of people out there already have experiance with this.
Could y'all let me know or give links for:
- What to whatch out for
- Know issues
- Driver availiblity
- Any problems using older versions of LabVIEW with Vista
- Any thing else I may need to know.
Joe V
"Lockheed" Joe
Testing Blog"
(4,426 Views)
THe "biggy" is VISTA implement security by keeping exe's and data files seperate. It is a common practice to put data files or config files in sub-folders of the app. VISTA doe not allow this, so plan for writting data to another location outside the app folders.
Ben
(4,422 Views)
So maybe we should all start storing our configuration data somewhere secure like in, oh I don't know... maybe a DATABASE?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,404 Views)
Mike...
Sure, right after you get the API calls figured out for running on VISTA and RT get back to me.Smiley Wink
Ben
Message Edited by Ben on 01-07-2009 10:49 AM
(4,402 Views)
Known Issues: Typical Vista issues
Driver Availability: Depends on what drivers you're using. The big ones all have Vista versions.
Older versions of LabVIEW: Older versions of LabVIEW are not officially compatible with Vista.  LabVIEW 8.2.1 was the first version that was "officially" compatible with Vista.
Anything else you should know: don't use Vista. Smiley Wink
(4,380 Views)
Accepted by topic author LockheedJoe
For further information about earliest versions of our drivers and software that are compatible with MS Vista, please refer to the link below.
http://zone.ni.com/devzone/cda/tut/p/id/6893
Please let us know if you have further questions!
Anna Kozminski
(4,354 Views)
Thanks Anna
"Lockheed" Joe
Testing Blog"
(4,297 Views)
