LabVIEW application run on Windows XP Embedded
I'm doing a Embedded system based on Windows XP Embedded operating system.I want to make a LabVIEW applications which can run on it.I see a lot of paper that show the LabVIEW does not support Windows XP Embedded.I want to know whether the official has already solved this problem?Or someone has done the same thing successful?
(3,738 Views)
Who is the official? NI?  If it isn't supported, NI is unlikely to be trying to solve the issue as we are a bit beyond XP.  You'd need to find unsupported methods to hack it a bit.  I'm not sure you'll enjoy this process
(3,727 Views)
thanks a lot !
(3,717 Views)
