LabVIEW speech recognition
Hello, I just want to ask help. I have seen the video about the voice recognition in labview. Can we get the VI's that were used in that technology. Thanks. You're immediate reply is very much appreciated.
Message 1 of 32
(7,817 Views)
Well, that's usually why most people come here. Smiley Wink
Unless you're @alfa1. But then, he's probably coming for the same reason. Smiley Very Happy
What video? Link?
As asked before, please provide a link to what you are referring to.
Message 2 of 32
(7,810 Views)
http://www.ni.com/swf/flv/labview/us/vista/vr/   hello, here's the link i am pertaining to. Who's alfa then? Sorry, I just badly need it. 😞 Thanks
Message 3 of 32
(7,806 Views)
see here: http://forums.ni.com/t5/LabVIEW/Voice-Recognition-with-LabVIEW-and-Windows-Vista/td-p/581702
Please do a search. The above link can be found by a simple search which would have taken you about 3 seconds.
Message 4 of 32
(7,800 Views)
Thank you so much. I'm sorry. I was just in a hurry. 😞
Message 5 of 32
(7,795 Views)
ahmmmmm sir, I just want to ask if this is applicable to microsoft too? I was wondering if this will be applicable too
Message 6 of 32
(7,792 Views)
I don't understand your question. The example discussed in that videos uses .NET, which is a Microsoft technology. If that is not what you are asking, please rephrase your question.
Message 7 of 32
(7,772 Views)
sorry sir, but don't worry I already have used some of the VIs that I find useful in my project
Thank you so much.! 🙂
Message 8 of 32
(7,763 Views)
I'm working on Speech Recognition Project.But I'm stuck at the MFCC.
Till now what i have done is...
  • Acquired Speech Signal.Detected it's starting and ending.
  • Pre emphasized it and divide it into "20ms frames" with 50% overlap.
  • Took FFT of each 20 ms frames and thus generated the Frequency spectrum.
  • Created 20 Mel Filter bank filter and multiplied "each frame's frequency response" with melfilter banks to get the log energy of each triangular filter.
  • Took DCT of log energy' s obtained from triangular bank filters for each frame and thus generated first 12 MFCC for each frame.
My doubt is, now i have 12 MFCC for each frame. Should i add all of them up to get one set of 12 MFCC's?
Was the method done by me for finding the MFCC's correct..?ie taking the MFCC from frequency response of each frame.?
Suppose my method is correct till now.What should i do next.?
I was comparing these MFCC for each frames with MFCC generated from utterance of the same word using euclidean distance and mahalanobis distance.?
Suggestion please.. 🙂
Message 9 of 32
(7,712 Views)
Can anyone help to get speech recognition labview function?
I really need it urgent basis.
Message 10 of 32
(7,120 Views)
