LabVIEW cannot detect connected instruments
Hi user,
@solarfacility_user wrote:
Are there supposed to be separate drivers for Windows and LabVIEW?
Yes.
Every hardware you connect in/at your computer needs a hardware driver for Windows:
  • A PCIe-GPIB card needs a driver, provided by the manufacturer of that card.
  • Any USB device either uses default Windows drivers (like for HMI devices) or also brings a specific driver supplied by the manufacturer…
Message 11 of 17
(1,649 Views)
Correct me if I'm wrong, but, I assume that this is the Windows driver for the spectrometer, with its icon in a separate image. I could not find the Windows driver for the sourcemeter though. I could not even find the CD installer for it. I tried looking for it on the internet but I couldn't find it.
Message 12 of 17
(1,643 Views)
Hi user,
This looks like an example/manufacturer application to actually remotely control the Spectrometer. This (most often) is something different then the driver needed for the communication bus/protocol!
Ask the manufacturer.
(As you don't provide any specific information about your devices we cannot even help you with searching for drivers!)
The same applies to the "PCIe-GPIB" device: ask the manufacturer of that card for suitable drivers…
Whatever you do: read the manual and ask the manufacturer's support!
Message 13 of 17
(1,639 Views)
I'm assuming that the "PCIe-GPIB" one is the GPIB-connected Keithley sourcemeter, but it says that Windows does not have a driver associated with your device, even though I already installed the drivers for LabVIEW, unless there is a separate driver for Windows. And I'm assuming that the "LPT-1" connection is the HORIBA MicroHR Spectrometer. Are there supposed to be separate drivers for Windows and LabVIEW?
What is the model and manufacturer of the PCIe-GPIB?
I am guessing it is not a NI GPIB interface.
Even if it was NI-GPIB it would still need its own Windows drivers plus NI-VISA and NI-488.2 installed
Also you might have to jump through a few extra hoops to get other manufacturers GPIB interfaces to work
=== Engineer Ambiguously ===
Message 14 of 17
(1,630 Views)
The GPIB cable that I used was the Type X2 one from NI (Model 763507B-02). Should it register as NI-GPIB in NI-MAX?
Message 15 of 17
(1,616 Views)
?  That's a data cable.  That won't register as anything.  You sure you have the right part number?
Bill
CLD
(Mid-Level minion.)
Message 16 of 17
(1,611 Views)
Hi user,
We ask for the GPIB PCI card and you tell about a GPIB cable (this is all I found for that material number, NI doesn't know anything else about it).
Where do you connect that GPIB cable to - at both ends of the cable!?
Again: which GPIB card is built into your computer? Which manufacturer and which type?
Message 17 of 17
(1,605 Views)
