01-18-2006 08:20 PM
01-19-2006 07:45 AM
01-19-2006 11:30 AM
I uninstalled and reinstalled three times. I am working with NI and following their suggestions, but they have not figured it out yet either. That is why I wrote this on the discussion forum. I am hoping that someone else found this problem and has a way to fix it that NI may have missed. Thanks.
01-19-2006 01:32 PM
01-19-2006 01:51 PM
Yes, the right click seems to bring up the appropriate menus and perform like it should in other applications. Thanks.
01-19-2006 02:28 PM
The only things that should come into play when right clciking should be tool selection or just in time advice.
I believe these two switches in the LabVIEW.ini file should shut those down.
requireAutoTool=False
AdviceEnabled=False
Does an earlier version of LV work?
Please let us know what the final solution is.
Ben
01-19-2006 04:21 PM
I could not find a Labview.ini in LabVIEW 8.0. Not only in the system that does not work, but also in a computer I have that is working. Should I have this .ini file for LabVIEW 8.0?
To update those interested, I installed LabVIEW 8.0 and associated drivers (MXI-4, PXI, 4472,6541, 1409, 6713, 2532, 4060, 6221 and GPIB) to another PC. It appears to be working so far. I say so far, because it worked fine at first on the system that is giving me a problem now. I still would like to figure out what the problem is on the newer HP workstation. I may have to start from a clean slate and reformat the computer. Thanks.
01-19-2006 04:52 PM
You should have LabVIEW.ini under C:\Program Files\National Instruments\LabVIEW 8.0 (or equivalent LabVIEW 8.0 folder). I am not sure what happened, but you may try reformatting as you noted if that's not completely detrimental to other installations you have.
Best Regards,
JLS
01-19-2006 05:31 PM
You are correct. It was right where you said it should be. For some reason doing a search does not find it. Anyway, here it is. Thanks.
[LabVIEW]
IsFirstLaunch=False
menuSetup="default"
saveFloaterLocations=True
SaveChanges_ApplyToAll=True
paletteStyle="NamedIcons"
ProbeDefaultCache="C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\_probes\default\AnalogWaveformProbe.vi;C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\_probes\default\ConditionalErrorProbe.vi;C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\_probes\default\CtrlRefProbe.vi;C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\_probes\default\DDTProbe.vi;C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\_probes\default\DigitalWaveformProbe.vi;C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\_probes\default\PictureCtrlDefault.vi;C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\_probes\default\PixmapCtrlDefault.vi;C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\_probes\default\RendezvousRef.vi;C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\_probes\default\SemaphoreRef.vi;C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\_probes\default\StorageRefnumProbe.vi;C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\_probes\default\StringNotifierRef.vi;C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\_probes\default\StringQueueRef.vi;C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\_probes\default\VIRefProbe.vi"
RecentFiles.pathList="C:\Andy\LabVIEW 8\NiDMM_start.vi;C:\Andy\LabVIEW 8\HP 3478A_VISA.vi"
01-19-2006 05:35 PM - edited 01-19-2006 05:35 PM
Message Edited by alias100 on 01-19-2006 05:37 PM
