LabVIEW closes when I right click mouse on front panel or block diagram
Do yo have any fancy third-party mouse drivers/utilities installed?
Message 11 of 18
(1,190 Views)
I don't think the mouse software is anything other than what comes with the windows operating system.  The mouse is still the older ball type.  The only software that I can think of that may be suspect is the software the IT department puts on that controls many aspects of the PC.  I had to remove the antivirus software because the IT group does not allow me to disable the antivirus software during installs.  I have a colleague working with the IT department determining the best way to do a complete reset of the system and still be company legal.
I noticed another peculiar thing that happens using LabVIEW 8.0.  When I try to view the tools pallette it will not show.
I can also add that the older machine that I installed LabVIEW 8.0 and PXI drivers is still operating just fine.  I did this to verify that there wasn't some issue with my LabVIEW 8.0 CD.  I might add that this machine also uses the same software that the IT department requires, so I could be wrong about my concerns of the IT required software.  Thanks.
Message 12 of 18
(1,186 Views)
Now I have problems.  The same thing is happening to my other PC.  I spoke too soon.  What ever is happening does not occur right away after installation.  The computer and LabVIEW work for awhile then something happens when the computer gets turned off a few times or maybe goes into sleep mode I don't know anymore.  This is very frustrating.
Message Edited by alias100 on 01-19-2006 07:42 PM
Message 13 of 18
(1,179 Views)
" I did this to verify that there wasn't some issue with my LabVIEW 8.0 CD."
Got another copy?
Ben
Message 14 of 18
(1,170 Views)
The saga continues.  I installed LabVIEW 8.0 and all of the same drivers onto a laptop.  The program works fine on it.  The only difference is that I cannot actually hook up to my PXI using the laptop.  This may suggest that after I install the MXI-4 and associate each piece of hardware with its driver that something happens.  It will still work right away, but when the computer goes to standby or gets shutdown something happens that creates a problem when I start-up.  I also noticed that the PC with the MXI-4 card in it will not turn off during shutdown.  It says windows is shutting down and then locks up.  I have to use the hold-button turn off routine.
NI is still as puzzled as I am, but I think someone familiar with the hardware might be able to look at the system information and hardware resources and see if there is something that I am not familiar with.  Does this seem possible or do I have to keep trying diferent things and hope I get lucky?  Thanks.
Message Edited by alias100 on 01-20-2006 02:06 PM
Message 15 of 18
(1,149 Views)
Laptop:
What problems are you seeing when you start up?
>>"something happens that creates a problem when I start-up"
PC:
If you remove the MXI-4 card from the PC that will not shut down properly, does this remedy the problem?  If so, there may be a problem with resource allocation in the BIOS.  What kind of PC do you have?
Message 16 of 18
(1,115 Views)
I think I have it working.  The machine I finally got LabVIEW working on is a Hewlett Packard Kayak XU800.  What I had to do to make it work is install LabVIEW first and restart the PC.  Then I installed the drivers and restarted the PC.  Then I unplugged all of the cards in the PXI chassis except the MXI-4 card.  I inserted the MXI-4 PCI card into the PC (PC off of course) and turned on the PXI chassis and then the PC.  The PC recognized the hardware and associated it to its driver.  Next I shut down the PC and PXI chassis and plugged in the next PXI card.  I restarted the PXI and PC and it recognized the new hardware and associated it to its driver.  I did this procedure for all nine of my PXI cards and verified that LabVIEW was still working between each step of the way.
I would like to thank those who helped me figure this out.  Thanks again.
Message 17 of 18
(1,087 Views)
" would like to thank those who helped me figure this out.  Thanks again."
NO Alias100....
It is we that should thank you!
If I am ever faced with a similar issue, your update re:how you got things working, will save me a lot of headaches Smiley MadSmiley Sad
Maybe next time we will be able to re-pay the gift.
Ben
Message 18 of 18
(1,078 Views)
