LabVIEW compatibility
Hello everyone,
i am using LabVIEW for the first Time and have a question.
it is possible to a LabView code from a old version (in this case from LabVIEW 51.1) to a new version?
Thank you for your answers.
Message 1 of 9
(4,920 Views)
Yes,It does
Message 2 of 9
(4,917 Views)
Hi Fradjo,
in case you need help to convert such old VIs you could use this conversion board!
Message 3 of 9
(4,914 Views)
Thank you Knight of NI ,I will use it
Message 4 of 9
(4,906 Views)
i Have opened it in LabView 8.0 but I have to many errors, and i don´t no how to resolve the problem.
Message 5 of 9
(4,755 Views)
Hi Fradjo,
Generic answer to your generic statement:
  1. Learn LabVIEW.
  2. Debug your VI.
  3. Resolve one error after the other…
Message 6 of 9
(4,746 Views)
Post the code and we can have a look.  Most errors I have ran into from upgrading that old of code is from the usage of Traditional DAQ, which has been obsoleted and replaced with DAQmx.
You could also look up an NI Alliance Partner and hire them to help your upgrade process.
Message 7 of 9
(4,728 Views)
Thank you for your answer crossrulz. i can´t post the  code here. the enterprise where i work don´t allow it. in the case that you are meaning, how can I solve the problem?
Message 8 of 9
(4,663 Views)
If it's a DAQ-issue this is a good start, see if it fits your problem.
https://www.ni.com/en/support/documentation/supplemental/06/transition-from-traditional-ni-daq--lega...
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 9 of 9
(4,648 Views)
