Non-unique custom error codes
Hi all,
I seem to be getting multiple error code matches from my custom error rings when passed to General Error Handler.
I have multiple custom error code files located in <install path>/user.lib/errors that share error code values e.g. File 1.txt for one application contains:
<nierror code="5007">
Steady Aerodynamic Coefficients (dCmCofG_da) suggests an unstable model
</nierror>
File 2.txt for a completely different application contains:
Invalid modulation [ AM | CW | FM | LSN | USB ]
</nierror>
When the error occurs I use an error ring constant applicable for the application.
When triggeredtThe resulting output is:
Warning 5007 occurred at MRET Model.lvclass:Read Steady Aerodynamic Coefficients.vi
Possible reason(s):
Should the error code values be unique across the custom error files?
Thx
Tadders
(3,496 Views)
They are available for "customization" as the User wants.  My approach is to assign a unique code for each "identifiable" error to aid me (and the users of my routines) in understanding what the error represents, but there are no "rules" for this.
Bob Schor
(3,482 Views)
Hi Bob,
Thanks for your reply - that is how I use custom error codes!
My problem is if I have multiple error code files, I get a message which is derived from both.
Phill
(3,457 Views)
Hmm -- I've never used "multiple Error Code files" -- I tend to have the Error Code files local to the Project where the Errors are being "trapped".
Bob Schor
(3,450 Views)
Hi Bob,
Ah, we package them for installation into user.lib/errors
Phill
(3,449 Views)
Aha, I understand the problem.  As my mom used to say, "Don't Do That!".  [I'm only kidding ...].
Bob Schor
(3,444 Views)
We need a "namespaced" error code so that your library can have error 5007, AND another library can throw the same error, BUT you can EASILY distinguish.
Obviously in half 2019 it's a too advanced and complicated feature for NI to implement.
I hope they will implement it in Labviw NXG 72.2 around the year 2052 when my personal time-space machine devie should be ready for the mass production.
Meantime, remember to support NI with regular LV subcription
Cheers.
(3,366 Views)
