LabVIEW crashes when I try to debug on a remote computer
Hello
I have a problem in my application and have to debug it therefore. The application is running on a computer only installed LabVIEW Runtime 8.2. Therefore I want to use remote debugging. But my LabVIEW development system crashes when I connect, only a error message from windows appears. When I restart LabVIEW, no error can be examined at startup.
When I only open a SubVI of the application and close the main VI, debugging works without any problem. (All the VIs are called dynamicly.) I can not debug the application on the development computer because the hardware is missing.
Does anybody have similar problems? Do I have to avoid something in my application to be able to debug?
Greetings from a perplex shb
(2,894 Views)
Hello again
I have some News:
I sent a request support including the lvlog*.txt file. (I tried until that one was created...) I prepared an example for them. I mentioned that the error does not occure when the VIs are in the application (in the exe file) and not called dynamicly. But I do not want all the VIs in the application because updating is more time consuming.
Greetings
shb
(2,882 Views)
