LabVIEW dll call complex struct
Hi
I am just créating a LabVIEW library for a driver Dll. The Dll contains some complex structs. I just would like to know if I can get around creating a wrapper Dll for these calls.
This is an example of one function call:
Error AA_querySlaveInfo(Handle hSlave, SlaveInfo* pSlaveInfo,
int flags);
 typedef struct {
  int vendorId;
  int productId;
  int revision;
  int serial;
  const char* group;
  const char* image;
  const char* order;
  const char* name;
  int objCount;
  DataObjInfo* objs[1];
} SlaveInfo;
typedef struct {
  int objType;
  const char* name;
  int bitLength;
} DataObjInfo;
Help is very much aprechiated.
(3,407 Views)
Accepted by topic author Keppi
Hi Keppi,
 its not possible, sorry. Without the last entry in the struct it would work, but that pointer to the other struct... you'll need a wrapper for that!
I hope that helps,
RMathews
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
(3,376 Views)
Oh well, I thought so..
So thanks for confirming my misery 🙂
(3,365 Views)
