LabVIEW error 44 and corrupting programs
The compaitibility chart shows LV 2013 to be NOT compatible with Windows 10.  The earliest version of LabVIEW to support Windows 10 officially is LV 2015.
Bill
CLD
(Mid-Level minion.)
Message 11 of 34
(3,457 Views)
Interesting, we have been running Windows 10 for over a year on multiple machines with hundreds of apps.
Message 12 of 34
(3,453 Views)
I said, "officially".  I've seen people successfully run LV 7.1 on Windows 10.  The problem with running unoffically supported LV/Windows combinations is that... well... it's not supported.  And it's likely that no one will be able to explain any weird problems you might have, because of the additional issue of incompatibility in the first place.
Being that you've been using LabVIEW for twenty years, I'm sure you've seen this chart before.
Bill
CLD
(Mid-Level minion.)
Message 13 of 34
(3,450 Views)
Like I said, I installed and removed LV several times on this machine, using the link to NI that they gave me.  Out of desperation I removed LV and reinstalled it using the original DVDs and updated from there.
It appears that may have fixed the problem.
Message 14 of 34
(3,411 Views)
Having the same problem of Labview error 44 corrupting programs on Windows 10 machine. Good to know that a CAR has been filed to fix it. Very annoying. Lost a whole day of work due to this.
Message 15 of 34
(3,353 Views)
What version of LabVIEW are you running?  I'm running 13
Message 16 of 34
(3,336 Views)
Can anyone with NI provide an update on CAR 597858?
Message 17 of 34
(3,236 Views)
Thanks for checking back in on this. I looked up the CAR and it is still open and assigned to our R&D software engineers. As of right now there is no target date or target release version. However, there have been more reports from other customers running into this same issue, so it should be moving up in priority for R&D.  All I can say is that the CAR number will be listed (597858) in the bug fixes portion of the readme in the patch that it will be a part of.
Jason O
Jorr-El
Systems Engineer
Testeract: Automated Test Specialists
Message 18 of 34
(3,214 Views)
I upgraded to version 15 and I am still seeing the problem.  My boss is about to throw LV out the window.
Message 19 of 34
(2,870 Views)
As a recap.  Here is the type of error I am getting.  LabVIEW:  Failed to load dynamic library because of missing external symbols or dependencies, or because of an invalid file format.  The file 'XXXX.vi could not be loaded.  This happens now that the file is corrupted.
I keep getting an error from time to time that says I don't have permissions to access the drive when I go to save the program after an edit.  I can cancel the save and ignore the error and try again and it saves it.  That is a pain, but having it corrupt the file on the network drive really sucks.  My IT guy is getting tired of pulling the file back out of the backups.
Message 20 of 34
(2,865 Views)
