10-30-2025 02:45 PM
Reproducibility is the hard part. We have an NDA with NI so no worries about IP.
10-30-2025 06:59 PM
A couple things you can look at or try:
10-31-2025 11:06 AM
My entire computer freezes from time to time. It's because Windows is the computer equivalent of untreated epilepsy. You never know when it's going to have a seizure.
10-31-2025 12:18 PM
Yes, but not what I'm experiencing. What I experience in LabVIEW is orders of magnitude worse than everything I even otherwise see in Windows.
11-03-2025 06:51 AM
I had a similar behaviour in LV2014 in a virtual machine in a somewhat complicated project. Sometimes LV froze for a few (several) seconds, then all windows reshuffled and then it pretended nothing had happened.
11-03-2025 07:28 AM
There's no network drives and my machine is in high performance mode.
This only happens with LabVIEW not other applications. When it starts happening it can usually be resolved by clearing the cache and re-loading everything (though that takes about 40 minutes so it's pretty painful). I do that roughly once a week to stave off these issues. I have seen certain vis appear to be more prone to this happening.
11-03-2025 08:45 AM
Have you tried making an Anti-virus exception on .vi's? That can often cause issues.
11-03-2025 11:09 AM
Can you try installing ProcMon and see if it shows what LabVIEW (or something else) is doing during the freezing?
https://learn.microsoft.com/en-us/sysinternals/downloads/procmon
