LabVIEW interface with Real-Time Linux
I'm looking for a library that would provide VI's that access shared memory in real time under linux.  I stumbled across this website:  http://www.adass.org/adass/proceedings/adass00/P2-50/   however, the links to the libraries are unavailable.  Specifically, we're looking at real-time FIFO communication with a shared memory structure.  I apologize if this is available under newer versions of LabVIEW for Linux, I'm not incredibly Linux-savvy!
Much thanks!
(2,816 Views)
Howdy,
That page looks quite old. Can you provide a bit of background on your application? Also, what versions of Linux and LabVIEW you are using? If you feel that this is a feature that should be added, please to create a Product Suggestion. Have you attempted to contact the makers of that library?
Joshua B.
(2,779 Views)
