Move element in array individually
 Hello
 I'm trying to make a vi that could move individual element in an array
 What I did was, I have a pict ring in an array so that I can have as many picture that I need
 But the problem is, if I want to move the picture, I'll end up moving the whole array
 Is there any way that I could try, to be able to move only the element?
In the vi that I attached, if I link Node-TCP-FTP, I can then move those 3 at the same time
I'd like to be able to produce several of Node-TCP-FTP so that I can connect the nodes to each other later
I'm trying to make each Node-TCP-FTP pair to be independent so that user can move it wherever they like before connecting node-node
I tried using array, but it gets mix up in the end
It won't be a good thing if I limit the number of Node-TCP-FTP pair that the user can make if I were to use separate ring for each of it
Is there any other way that I could try?  or is it possible to move the selected element from the array so that I can make an array of Node, TCP, FTP instead of what I've done?
Thanks 🙂
(2,906 Views)
Your description is very confusing to me.  You talk about having arrays and multiple inpdependent pairs of these objects, but you only have one set of objects set up and they don't have anything to do with arrays.
I think you should probably be working with picture controls rather than picture rings.  Search the forums, I think Ben had a large nugget on working with pictures.
PS.   There is no such word as "traffics".  It should be "traffic".
(2,886 Views)
