LabVIEW load error code 3: Could not load front panel
Yes  I got the same error.
Chethan
Message 141 of 176
(2,899 Views)
The most recent information about upgrading to the latest version of LabVIEW.
Overview of the Recommended Upgrade Process
LabVIEW 2014 Upgrade Notes
Message 142 of 176
(2,899 Views)
Thanks for the upgrade document link. I will follow the procedure. Please help me if I get any sort of error. I will post here.
I am gonna upgrade it again to 2014 version now.
Thanks I appreciate it.
Chethan
Message 143 of 176
(2,895 Views)
the first step : Don't forget to make a back-up for your project
Message 144 of 176
(2,890 Views)
Yes. I will save the fles in different directory before I start.
Chethan
Message 145 of 176
(2,887 Views)
I have encountered the same error using LV 2009, and have had no success using the 2009 - 2009 f3 patch suggested here. Is there an alternative solution for the 2009 version?
Thanks in advance,
J
Message 146 of 176
(2,556 Views)
Hi jifarq,
your VI opened with LV2011 and saved for previous in LV2009…
(Lots of missing subVIs, but no problems to load/open!)
Message 147 of 176
(2,554 Views)
Thank you so much!
J
Message 148 of 176
(2,549 Views)
Hi. I'm obtaining the same error to open the program attached. This program was made in labview 7.1 and I am trying to open it in Labview 12.0f3, 64bits. I tried the solution to add a line in the .ini file but it didn't work. Does anybody have suggestion? Best Regards.
Message 149 of 176
(2,479 Views)
  • I cannot open it in the newest LabVIEW (32bit) either.
  • What line did you add to the INI and why?
  • Why is the VI so big?
  • Are you sure the VI was not saved without front panel?
  • Any particular reason you are using 64bit LabVIEW?
Message 150 of 176
(2,475 Views)
