LabVIEW load error code 3: Could not load front panel
Have you tried recovering a much older version of the VI?
Message 41 of 178
(4,524 Views)
Hi RMathews,
Will you please help me for same..
I got the same LabVIEW LOAD ERROR 3 : Couls not load the front panel
I have tried all mentioned steps but didnt found any success.
Please help me for same...Waiting your reply.
just ignore subvis if any....
Thanks in advance....
Message 42 of 178
(4,511 Views)
thats the problem, i havn't a much older version of my vi. only a very old version.
Message 43 of 178
(4,502 Views)
Hi there,
I tried to fix some of the vis. I hope its working for you!
Cheers, RMathews
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
Message 44 of 178
(4,498 Views)
and another one
Ramona Lombardo
Message 45 of 178
(4,491 Views)
thanks a lot, you are great! how you do this?
Message 46 of 178
(4,492 Views)
Hi evolet23
you can solve the problem in LabVIEW 2011 SP1
Instructions to fix a corrupted VI in 2011 SP1.
1. Close LabVIEW
2. Add connPaneRecoveryMode=True to the LabVIEW.ini file
3. Open the corrupt VI.
4. Push Ctrl+A on the block diagram and the copy and paste to a new VI.
5. Save the new VI.
6. Close LabVIEW and remove the ini token (VERY IMPORTANT)
7. Restart LabVIEW and load the new VI and verify it is correct. Save
Message 47 of 178
(4,488 Views)
Lots of thanks sir....
It saves my 2 days work.....
Message 48 of 178
(4,476 Views)
i tried this, but it didn't work.
Message 49 of 178
(4,473 Views)
did you try it with LabVIEW 2011 SP1?
Message 50 of 178
(4,470 Views)
