LabVIEW program error
I am new to LabVIEW. So kindly request your help.
I am working on Raman Spectrometer and now the output graph has shifted left by 10 units
in X-axis scale. For an example, Usually I see GaN peak at 570 cm^-1(x-axis value), but now I can see
that peak at 560 cm-1. Similarly, each output graph has shifted by 10 cm^-1.
What can I do to correct this LabVIEW error?
(2,650 Views)
You should probably post this in the LabVIEW forum.  I see if I can have it moved...
Depending on the code it might just be the axis offset, but it is impossible to tell without seeing code. Is it a waveform or xy graph? What is the data type (array, waveform, dynamic, etc.)
(2,643 Views)
