LabVIEW program help
Is your PC is installed with LabVIEW?Develop One More VI Explicitly for Data Logging and run this code in PC instead of Dash Board.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 11 of 45
(3,423 Views)
Hi Steve,
I have checked and I'm sure the path is definitely correct. Any other ways I can troubleshoot this problem?
With thanks,
Sonata
Message 12 of 45
(3,403 Views)
Hi Palanive,
Im currently using LabVIEW installed on my laptop.
We need to be able to run our code solely on DashBoard only, is that why we need one more VI for Data Logging to run on LabVIEW?
With thanks,
Sonata
Message 13 of 45
(3,402 Views)
As you are not able to access the PC path to Log data, Data logging can be made in PC/laptop otherthan Dashboard.
From dashboard the values can be transfered via shared variables.
Message 14 of 45
(3,398 Views)
Hi Palanive,
Does that mean we create a new VI here just for the data logging part?
With thanks,
Sonata
Message 15 of 45
(3,394 Views)
Hi Palanive,
With thanks,
Sonata
Message 16 of 45
(3,393 Views)
yes its just for logging data in PC, which may not be included in myRIO, Project its kept separate in PC for DataLogging Make sure you are running this VI When required.
Message 17 of 45
(3,386 Views)
Hi Palanive,
Instead of taking the trouble to do all this for the path for the excel, is there another way of sorting out using the array functions only?
With thanks,
Sonata
Message 18 of 45
(3,382 Views)
Your requirement is to save data rite?
how save can be handles using array functions?/ whether you are saving data to overcome someother probelm?
Message 19 of 45
(3,378 Views)
Hi Palanive,
We are considering the 'Write to spreadsheet' function because we wanted the sorting function of Excel, but we are facing problems, thats why I am asking for other alternatives within LabVIEW that can do the same thing.
With thanks,
Sonata
Message 20 of 45
(3,373 Views)
