LabVIEW program help
Is it possible to store data in dash board itself?, in that case you can store the data in Dash board itself as .txt file.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 21 of 45
(3,493 Views)
You want to sort 2d array ? Please explain problem Clearly so that it is easier to suggest a possible solution.
If you want to sort 2d array according to what you want to sort? Column? row ?
-check this example https://decibel.ni.com/content/docs/DOC-13719
uday
Message 22 of 45
(3,487 Views)
Hi Palanive,
I have made changes to my VI already, the program is running fine, however when I open the excel sheet, nothing is recorded, is there something wrong with my connections? Attached is my vi.
With thanks,
Sonata
Message 23 of 45
(3,487 Views)
Where is this path Located "C:\Users\Y410P\Desktop\Testing.csv" PC or Dashboard?
Message 24 of 45
(3,480 Views)
Hi Palanive,
It is on PC.
With thanks,
Sonata
Message 25 of 45
(3,478 Views)
Hello Sonataaaaaa,
This is the actual problem, you are running code on Dash board and the Path to be saved is in PC.
So it wont save, either you should have network path which should be mapped in dashboard or you need to run Logging in PC or You should be able to log file in dashboard itself.
Message 26 of 45
(3,474 Views)
Hi Palanive,
Thanks for addressing the problem, we cannot find a way to map a network path in Dashboard..(How do we do this?)
With thanks,
Sonata
Message 27 of 45
(3,468 Views)
Hi udka,
Yes, we are trying to sort 2D array, we are thinking of writing the values we have measured to a spreadsheet, sort in excel and get it back to labview, is there a simpler method to do it?
With thanks,
Sonata
Message 28 of 45
(3,456 Views)
You don't need to write to file get it back unless you want to save the data.
- You want to sort based on what?
- you want to sort entire array? Or row wise ? Column wise?
- Did you check the example in my previous post?
uday
Message 29 of 45
(3,453 Views)
Hi udka,
Yes, we need the data to be saved, however no matter how I try, I cant get anything to be displayed on the excel file.
We are using the sort function to create a high-score system by sorting the top ten values.
With thanks,
Sonata
Message 30 of 45
(3,452 Views)
