LabVIEW proverbs!
altenbach wrote:
pandersen wrote:
Thou shalt forget everything previously learned about programming with text based languages when using LabView.
That reminds me:
You have reached the first level of LabVIEW proficiency once you can spell it with the right capitalization. 😄
Wow, your remark automatically takes me to the first level of LabVIEW proficiency due to my utmost care for correct write-ups. 😛
So, my proverb:
Everything counts when you're working on LabVIEW.
Vaibhav
Message 171 of 305
(4,892 Views)
tst wrote:
As for the typedefs, standard typedefs are fine. Strict typedefs are relevant for specific use cases where you want the typedef to be used in the UI.
Makes sense! Thanks as it gives a good rule to remember.
Vaibhav
Message 172 of 305
(4,889 Views)
Message 173 of 305
(4,831 Views)
Try and keep your block diagrams to the size of your screen.  And if your block diagram extends beyond the size of your screen, ask your boss for a larger screen.
Message 174 of 305
(4,825 Views)
Be careful when you fight the text programmers, lest you become one.
Bill
CLD
(Mid-Level minion.)
Message 175 of 305
(4,808 Views)
Based on today's experience: To work with LabVIEW with wireless mouse with dying battery is like to convince V32 indicator to display negative numbers
LV 2011, Win7
Message 176 of 305
(4,695 Views)
Credit to Jeff Bohrer for this one. It can be referenced in full context in this thread.
IMHO NI should co-opt GEICO's slogan "So easy a cave-man can do it"- and understand it.
Message 177 of 305
(4,684 Views)
The new 'Clean Up Diagram' button works perfectly--as long as you interpret it as 'Scatter Objects Randomly'.
Message 178 of 305
(4,659 Views)
in this thread Darren replied to question about Feedback nodes...
"....esoteric Feedback Node questions really have no place in these exams."
Ben
Message 179 of 305
(4,434 Views)
Here's the link Ben referred to.
Certified LabVIEW Architect
TestScript: Free Python/LabVIEW Connector
One global to rule them all,
One double-click to find them,
One interface to bring them all
and in the panel bind them.
Message 180 of 305
(4,394 Views)
