LabVIEW shmoo plot
Does anyone have an example of making a shmoo plot like the one shown here? https://www.ni.com/en/support/documentation/supplemental/11/designing-semiconductor-ate-with-the-ni-...
Message 1 of 12
(7,916 Views)
??? What is a shmoo plot?  Didn't see anything labelled that way on the White Paper you referenced.
Message 2 of 12
(7,872 Views)
Look at number 5 custom debug tools.
Message 3 of 12
(7,867 Views)
Oops, there it is!  But I'm sorry to say that I have no idea how to make such a plot in LabVIEW!  I suppose I could "cheat" and use LabVIEW to call Excel and make the plot in Excel, then figure out how to "export" the plot back to LabVIEW, but that's surely not what is intended.
Message 4 of 12
(7,820 Views)
Looks like a simple intensity graph.
Message 5 of 12
(7,806 Views)
Except for the fractional values on the axis scales.  The intensity graph uses the indexes in the array as the axis values.  Of course the scales could have been customized.
Lynn
Message 6 of 12
(7,775 Views)
To my chagrin, I've never used (or thought I needed to use) an Intensity Graph.  Thanks for introducing me to Something Old, Something New in LabVIEW.
BS
Message 7 of 12
(7,754 Views)
Another idea: duplicate the plot on the waveform graph, and play with Fill Base Line option of both plots.
Message 8 of 12
(7,746 Views)
I have the intensity graph working almost right. I'm pretty sure it will fit my needs. I had never needed to use this kind of graph before so it wasn't on my radar. Thanks Darin.K
PiDi and you upload your vi in LabVIEW 2010?
Message 9 of 12
(7,741 Views)
Message 10 of 12
(7,737 Views)
